emergency brake not working properly
2007 KIA AMANTI
99,000 MILES
ALEXEI NIKOLAYEVICH
  • 15 POSTS
when I press the emergency brake pedal, the car still rolls, even if there is a slight slope. A long time ago I changed the emergency brake shoes, but it didn't fix the problem.
Car rolls, and when I driving sounds are heard from the rear brake rotor. I can guess only its brake cables stretched.
My question is where to start to disassemble brake cables. And check if they really stretched out or not?
Aug 29, 2021 at 3:46 AM
There is a good chance it is an adjustment issue. The cable can stretch, but they are adjustable. When you installed the new shoes, did you make adjustments at that point? If you look below, I attached directions for adjusting the shoes and the cables. Try this first and let me know if it takes care of the problem.
If you know there is a broken cable, let me know which one or its location.
See pics below.
Aug 29, 2021 at 8:32 PM
SQM
  • 6,383 POSTS
It sounds like you will need to adjust the brake. It is likely the issue.
Even though a cable can stretch you can always adjust for the extra length.
Also it is important that the parking brake gets adjusted while replacing the shoes.
https://www.2carpros.com/articles/parking-brake-shoe-replacement
Thank you.
Aug 29, 2021 at 8:40 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Have question. When I adjust the parking brake to 1/8", pedal not applied, and the drum should spin freely? I need to adjust 2nd adjuster (on Drrawing#2) And I don't know where the 2nd adjuster is located in my car, under the car body, or inside the car?
Aug 30, 2021 at 10:47 AM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Because after adjusting rear brake show, brake still not holding car. So I need to find a location for 2nd adjuster nut. Thanks.
Aug 30, 2021 at 10:53 AM
The adjuster will be under the vehicle. It is at what is called the equalizer assembly. That is where the front cable joins with the two rear cables.
If you look at the attached pics, I highlighted where it's located.
See pic below.
Aug 30, 2021 at 6:18 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Thank you,I will try to fix it, hope to do it right.
Aug 31, 2021 at 12:18 PM
Alexei,
You are very welcome. I know you'll do it right. When you tighten the bolt at the equalizer, that will pull the cable tighter. Just make sure you follow the directions. If you overtighten the bolt, the brakes could be on all the time. We don't want that. LOL
Let me know what I can do to help. If you have a chance, let me know how things turn out for you.
Aug 31, 2021 at 6:29 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Yes, i will tighten that bolt step by step, and same time after each adjustment. i need to put down the car, to check how it's tight or not.
I'm using a manual jack, it will be a little bit extra job for me. But hope will be done with this problem easy. Thank you again. I let you know how i did.
Aug 31, 2021 at 7:40 PM
Sounds like a plan. If you are using the jack which came with the vehicle, please be careful. They aren't the most stable things. Make sure you have safety jack stands to prevent it from coming off the jack.
Aug 31, 2021 at 9:38 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Hi guys, I did work yesterday with a parking brake. First I open the brake drum, check 1st adjustment nut, after crawling under the car, to find out 2nd adjustment nut.
Like you told to me:
"The adjuster will be under the vehicle. It is at what is called the equalizer assembly. That is where the front cable joins with the two rear cables."
By the way my catalytic converter was stolen and was easy to see what's going on under the vehicle. Because I took out the rear part of the exhaust pipe.
Anyway, I saw like 2 cables coming inside my car interior.
Its means 2nd adjustment nut only inside the interior. And I need probably take some part of floor carpet or even whole front center console between the front seats.
This is another project, because it's hard to make it, but will try.
I was surprised, to adjust the 2nd nut you need to do so much work, cause it lies under the rear carpet or center console? Go try to find out the location of the equalizer.
I Will check my email later. Thanks.
Sep 4, 2021 at 3:53 PM
On many Kia vehicles, that part is under the car. If you see two cables running into the floor pan, then the equalizer must be in the vehicle. You will need to remove the center console to access it.
I attached the directions below for removing the console below.
See pics below.
Sep 4, 2021 at 9:16 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
To pull out the gear shift knob, I think it's not possible. I partially disassembled the panel but in a different order. will try to do next from the pic.#4. It's so hard to do that there is no hope at all. If I can't do it, I will cut the plastic air duct from the heater to the rear passenger seats, to get access to the adjusting nut.
Sep 4, 2021 at 10:02 PM
It can be difficult. Let me know how things turn out for you.
Sep 4, 2021 at 10:49 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Today I disassembled apart the whole console between the front seats. And got easy access to cables with adjustment nut. After I start adjusting brake pads, on the left and right sides. I made a gap of about 3mm, it was spinning pretty easy. After that start adjusting the nut inside the cabin. But no matter how much I twisted the nut (#7, on the pic.)Part #6 was skewed. As if the right side is a little bit forward. And therefore Left wheel was tight, and the right wheel was revolved. I screwed up adjusting nut max. it's possible and now the left side is very tight, but the right side is very free.
I think it's only one reason Next step I need to order new right cable, from the dealer, and try to replace it. I hope it will be easy. Because nuts holding the cable to the hook behind the brake pads are a little rusty.
Of course, this is a question of I right, and right cable stretched out. But need tries to complete this renovation.
Alexei.
Sep 6, 2021 at 3:19 AM
If the left side is overtight, loosen it at the wheel. If the right side is too loose, you can adjust it up a bit to compensate.
It's possible that one side was tighter than the other when you started which caused the issue.
Let me know if that works for you.
Sep 6, 2021 at 6:56 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
But by instruction, I must adjust rear pads first, with a gap of 3mm. And I did it? After I adjust the nut inside the cabin to the maximum how it's possible, and still right rotor stays loose. I was trying to tight more brake pads on R. side. but it's getting very tuff to put on or take off the rotor from brake pads. Still, I want to change R.cable.
Sep 6, 2021 at 9:06 PM
Absolutely replace the cable if you feel it's stretched. As far as the adjustment, when you loosen the right side, it will move the shoes away from the drum and allow it to turn again.
Let me know if I can help or if you have other questions.
Sep 6, 2021 at 9:22 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Hello JACOBANDNICKOLAS. I was looking for a parking brake cable on site at KIA Parts Now.com and what they answered to me:
Thank you for contacting us. The Parts Specialist reviewed your inquiry per VIN provided and provided the following information;
- The part requested (59770 3F100) has been discontinued by Kia
Sincerely,
Customer Service Department
I will have to leave this problem for later.
And casually I have another problem with my cooling system.
My radiator fan don't turn on, and one round trip 20 miles, the car got overheated.
After that, it turned out the fan doesn't turn "on" when overheating.
I connected the fans directly to the battery, and both fans worked.
After that I checked the system turning on AC, same results, fan didn't start.
Now I want to check the fan circuit, but I don't know the location of the relays responsible for the fan operation?
If possible could you give me an idea where can I start to find the reasons for not working fans? Thank you.
Sep 11, 2021 at 3:26 PM
First, I found the cable you need on Amazon. Take a look at this link:
https://www.amazon.com/Genuine-OEM-597703F100-CABLE-ASSEMBLY/dp/B086N2ZTJB
As far as the fan issue, I would be happy to help. However, I need you to copy and paste your question to a new thread. We try to keep the threads specific to one topic so they are more helpful to others.
Here is the link to start a new question. Simply copy and paste your question and we'll get right on it.
I hope you understand.
Take care and let me know if that cable works for you.
Sep 11, 2021 at 9:16 PM
ALEXEI NIKOLAYEVICH
  • 15 POSTS
Yes, it's available on AMZ. Before ordering that OEM, I need to take a look, how to disconnect that stretched cable. Imagine it won't be easy, maybe I need a release tool?
Thank you for the update.
Sep 12, 2021 at 1:56 PM
To remove the stretched cable, you need to loosen the adjustment nut.
If you look at the attachments below, they provide the directions for replacing the cable. Take a look and let me know if you have questions.
See pics below.
Sep 12, 2021 at 7:23 PM
