Electronic Ride Control wiring schematic?
2000 BUICK PARK AVENUE
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MARKYFSPARKY
I'm working on my car listed above Base. except for the supercharger on the Ultra model, all items on the Base are basically the same.
I need Electronic Level Control "compressor side" female wiring schematic, as well as vehicle side schematic.
I am replacing my wiring connectors to the air strut compressor motor assembly, and mistakenly cut the compressor side connector off before realizing there are two white wires so now, I don't know which white wire goes to which factory wire.
Vehicle side male connector has: Blk, Grn, Org, Whi wires.
Compressor has: Blk, Blk/Grn, Whi, Whi wires.
I believe the two white wires on the compressor go to the exhaust solenoid. I need to know which to connect to the orange wire.
The factory harness male connector side.
Oct 13, 2024 at 9:14 PM
Sure, here is the wiring diagram for the autoride system for your car. Also, this guide can help you test the connections:
Oct 14, 2024 at 10:45 AM
