Hey Adrianam01,
When you start your vehicle warning lights will come on and then go out again. This is to show that the lights are functioning and then they will go back out if everything is okay.
This warning light test should happen immediately as you start the vehicle/turn the ignition on. The lights will only come on momentarily.
The lightning bolt warning light points to an issue with the electronic throttle control.
If the light comes on at all outside of this test period then return to the dealer and tell the the problem you are having.
Your vehicle should still be in warranty. The diagnostics and checks will be covered.
If in doubt it is always better to return to the dealer for them to run diagnostics to ensure there is not a fault.
Hope that helps, any further questions please do not hesitate to ask.
Regards, Joe
Apr 4, 2019 at 12:05 PM
