Electrical issues and car will not start stuck in anti-theft mode
1994 MERCEDES BENZ C220
250,000 MILES • 2WD • AUTOMATIC
0POINTGAMING
  • 5 POSTS
after charging a dead battery (less than a year old) and reinstalling it in the vehicle, the engine wont start the anti theft system is engaged (i used to be able to use the key in the door to lock and unlock the car resetting the anti theft system this no longer works either). The key fob nor the key will unlock all 4 doors and trunk. The horn also does not work. Tested all fuses with a multi-meter all fuses seem to be in working order, battery has juice, i am able to turn the cabin light on and off, the turn signals and emergency blinkers also do not work.
any suggestions as i am completely lost?
Feb 23, 2020 at 2:51 PM
If the only thing working is the dome light, it sounds like a fuse issue or connection issue. The immobilizer won't shut down everything.
I looked through wiring schematics for power distribution and it shows the power from the battery goes directly to the left footwell and then distributed from there. See pic 1.
Are you getting power to the maxi fuses shown in the picture?
Here are a few links you may find helpful:
https://www.2carpros.com/articles/how-a-car-fuse-works
Feb 23, 2020 at 7:01 PM
0POINTGAMING
  • 5 POSTS
I charged the battery for 12 more hours, The battery didn't have enough voltage apparently, now everything is working fine, however the ABS and SRS lights are now on. Cars never just work do they, lol.
Feb 24, 2020 at 8:50 AM
I agree. There is always something. As they continue to get more complex, this will become more and more common.
Now, just do some basics testing. Make sure the fluid is full and nothing appears disconnected. There should be a fuse for the ABS. If you look at the attached pic, it shows two fuses I need you to check.
Keep in mind, if you haven't driven the vehicle much, they light may go out on its own.
Feb 24, 2020 at 7:32 PM
0POINTGAMING
  • 5 POSTS
Light went out on its own all good thanks :D
Feb 26, 2020 at 4:46 PM
Excellent. It had to complete a specific drive cycle for it to turn off. I'm glad it's working properly again. Let us know if you have questions in the future.
Feb 26, 2020 at 6:18 PM
0POINTGAMING
  • 5 POSTS
I do actually have a second question. When reversing now the car lunges as if it's getting too much gas then after about 3-4 lunches it stalls out. this only happens in reverse.
Feb 27, 2020 at 5:09 PM
Since the battery was dead/disconnected, the computers may need to complete a relearn. They should do it automatically, but it may take a few miles for it to stop.
Have you put a lot of miles on it already?
Feb 27, 2020 at 5:54 PM
0POINTGAMING
  • 5 POSTS
Oh , it has got a ton of miles on it. It's like 250,000+.
Feb 27, 2020 at 6:22 PM
No, I mean how much have you driven it since the battery replacement?
Feb 27, 2020 at 9:02 PM
