Electrical wiring diagram for front and rear lights needed
2016 DODGE DURANGO
40,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
PAWEL_N
  • 178 POSTS
I bought the vehicle listed above from USA market. I live in EU country and I have to do some modification. I would like to know the wiring diagram for front and back lamps. I have change rear turn signal color and add rear fog lamp for EU regulations. I can see that there are 4 bulbs for reverse gear. I would like to know where the wires go to?
Thank you for yours reply.
Have a nice day,
Pawel
Mar 28, 2022 at 3:37 AM
Good morning,
I attached the wiring for the backup lights, park lights, and headlights.
The body control module is what controls the lights based on the input from the headlight switch. Check out the diagrams (Below). Please let us know what happens.
Mar 28, 2022 at 12:05 PM
PAWEL_N
  • 178 POSTS
Dear Roy,
Thank you for your reply. It is okay now. The diagrams are helpful.
But I can't find 4 white bulbs for reverse gear / backup light on rear/lift gate. There is only two wire - Left and Right side. Where is located split/junction point?
Mar 28, 2022 at 1:38 PM
I don't see any diagram with the 4-wire setup.
I circled the connectors, but they didn't give a location. The one is back by the taillights, but you will need to open the harness to check for that connector and see if it carries the extra wires for the 4-light system.
Mar 28, 2022 at 5:14 PM
PAWEL_N
  • 178 POSTS
Thank you for your help. :-)
Have a nice day,
Pawel
Mar 28, 2022 at 9:47 PM
PAWEL_N
  • 178 POSTS
There is on your diagrams the wiring for car hook too. But I cannot see the car hook in my car. Do all Durango have wiring for trailer? The last 8 numbers of VIN's are KC833672 and for the second Durango GC424738.
Mar 29, 2022 at 1:40 AM
No, they do not. It all depends on the harness that is installed on the assembly line.
Mar 29, 2022 at 4:17 AM
PAWEL_N
  • 178 POSTS
I have done the rear stop and turn lights. I have to add rear fog light. I would like to connect the front fog light with the rear fog bulb. Could you please add diagrams for front fog lamps? And location the proper wire/junction/connector on BCM for fog front lamps.
Have a nice day,
Pawel
Jun 25, 2022 at 6:56 AM
PAWEL_N
  • 178 POSTS
There are both yellow/amber turn signals.
Jun 25, 2022 at 10:34 AM
It looks like the fog light are controlled by the BCM. here are the fog light wiring diagrams you asked for. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 27, 2022 at 1:09 PM
PAWEL_N
  • 178 POSTS
Super :-)
Thank you very much for your reply.
Jun 28, 2022 at 12:37 AM
Good to hear, please use 2CarPros anytime we are here to help.
Jun 28, 2022 at 11:42 AM
PAWEL_N
  • 178 POSTS
Dear Ken,
Could you please add wiring diagram for horn in this car too?
Thank you
Oct 27, 2023 at 1:49 AM
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Oct 27, 2023 at 8:29 AM
