Electrical voltage gauge
2002 DODGE RAM
192,145 MILES • 4.7L • V8 • 2WD
LISA THOMAS
Voltage gauge in dash goes to nothing after a few minutes or a few miles, but turn key off and restart truck and it is back to reading half of normal until a few minutes or miles then nothing again. the battery seems to be charging. I am running lights and all, truck is still starting as if alternator is still working. can you help?
Jun 29, 2017 at 8:37 PM
Please remove the cluster and unplug it. Then plug it back in again, this will fix a bad connection at the cluster causing the problem you describe.
If that doesn't help then the gauge probable bad and you will need a rebuilt cluster which you can find on Aammzon or Ebay.
Please let us know what happens, we are interested to see what it is.
Jul 2, 2017 at 7:39 PM
