This is going to take a bit. The way it is broken down in my manual is quite odd. The fuse panel is under the dash.
For me to tell you what each fuse does requires looking up each fuse number, following a schematic, and then I can determine what it is for. See pic 2 for example.
Here is what I need you to do. Following the link above, identify which fuse seems to cause the electrical draw. Once you do that, tell me the fuse number based on pic 1 below. I will then determine what component or components that fuse powers.
I'm sorry I have to do it this way. Because of the model year, things are somewhat limited. Normally, I have a list of what each fuse does. This one doesn't. However, if you identify the fuse number, I can tell what it is for. I hope you understand. If we don't do it this way, I will have to attached nearly fifty confusing schematics.
Here are a few links you may find helpful as well:
Jan 30, 2020 at 6:40 PM
