The battery was weak so I went to change the battery and I put the cables on the wrong terminals and then for the jump start from jumper cables and put them on the wrong terminals. now all the lights are lit up on the dashboard and the alternator is no good. there's also a hundred watt amp on the positive battery cable that I fried. I don't see any other fuses fried. The car starts when I charge the battery now but the radio is not working. so I did the very least I know I need an alternator if I change the alternator and the hundred watt amp will all those lights on the dash go off and is it going to solve the problem? or could I have made a big mess of the electrical system in the car?
Jan 18, 2019 at 8:49 AM
