When you apply the brakes, do all lights turn off? Do the brake lights turn on?
I feel confident at this time that the cruise control issue is related to the brake light issue, but I need to know if the brake lights do turn on and the other rear light turn off.
Also, I want you to try something. Under the hood in the power distribution box, there is a relay called a TNS relay. Try switching it with another relay having the same part number and see if makes a difference. This relay could be the cause of most of the issues.
___________________
Pic 1 shows the relay in the wiring system. Pic 2 shows the location of the relay in the fuse/relay box.
Let me know what you find.
Nov 26, 2020 at 3:07 PM
