This is an interesting problem. Purchased this truck used. It idles fine, surges when accelerating,loses power up hills. Replaced plugs, wires, checked coil, checked and cleaned main ground,cleaned MAF with spray cleaner. intermittently, power at dash lights when key is turned but wont crank,checked ignition switch and movement of actuator "shaft". Theft light slowly blinking. Replaced fuse#3 obd port. also blowing fuse #23 engine compartment. Codes, 135,141,155,161,340,443. Any ideas would be appreciated.
Aug 18, 2019 at 7:32 PM
