Problem with the lights inside the car. There is nothing on the counter except the check engine. The gauges are not working. The radio is not working. Blower the same. The switch to change the drive to 4x4 also does not work, the same for electric windows. The car starts and runs normally, but after turning it off and even removing the key, the car continues to run. After disconnecting the clamp from the battery, the car goes out. Fuses checked and okay, none blown.
Mar 27, 2021 at 3:17 PM
