Okay, then at this point, I feel either we have an issue with the can-bus to the BCM or the BCM has failed. In the case where multiple modules DTCs are stored, the diagnosis will shift to the CAN bus. It could be related to the module itself, so confirm the wiring to it is in good condition and the connectors are not loose.
Is the scan tool able to communicate with the BCM? If there is no communication ability, then I need you to look through the directions for checking a no communication/can-bus information below.
The BCM is located in the right rear of the luggage compartment. I need you to locate it. Next, locate the gray wire with an orange tracer and the violet wire with an orange tracer. These are the can wires to the BCM. Inspect them. Make sure they are tight and undamaged. Also, confirm the gray/orange has a 2.5v signal to it.
If they appear good, try a hard reset. Disconnect the battery negative terminal and allow the vehicle to sit that way for at least 5 minutes. Reconnect it and there is a chance it will resolve any issues within the can network.
Let me know what you find. Also, the last two pics below show the two wires to the BCM I am referring to and the BCM. The last pic is a pinout of the connector at the BCM. I highlighted the two pins related to the CAN.
I hope this helps. Let me know if you have questions.
See pics below.
Feb 18, 2022 at 7:25 PM
