Healthy spark at coil, no spark at plugs. new distributor cap and rotor and rotor turns when cranking. Tony
Sep 27, 2019 at 12:48 AM
CERTIFIED EXPERT
Good morning,
Check the coil wire and make sure it is sending a spark to the distributor cap. If you have spark at the coil and not the plugs and you have a new cap and rotor, then it sounds like wires.
There is no spark coming out of cap. Leeds okay. it's like the rotor is sparking at the wrong position never had the dizzy out or adjusted it the car just stopped. Tony
Sep 27, 2019 at 2:03 AM
BOEKELMAN
MEMBER
It's a Chevrolet 350 1991 Silverado 1500 suburban.
Sep 27, 2019 at 2:16 AM
CERTIFIED EXPERT
Got it.
If you have spark coming out of the top of the coil, then the only thing left is the wires themselves.
Sep 27, 2019 at 2:47 AM
BOEKELMAN
MEMBER
The wires are okay the timing of the spark seems to to have changed by itself.
Sep 27, 2019 at 3:03 AM
CERTIFIED EXPERT
Do you have spark into the cap?
Sep 27, 2019 at 5:17 AM
BOEKELMAN
MEMBER
Yes, but the rotor and spark don't make spark at the right place anymore or time anymore.
Sep 27, 2019 at 5:32 AM
BOEKELMAN
MEMBER
So the spark is too far away from the contacts probably in between the contacts somewhere. Tony
Sep 27, 2019 at 5:42 AM
CERTIFIED EXPERT
This could be a bad distributor. The shaft may be worn out.
Sep 27, 2019 at 5:57 AM
BOEKELMAN
MEMBER
It happened all off a sudden I thought it was a spark sync pulse change from the timing so the coil sparks at the wrong time now.
Sep 27, 2019 at 6:14 AM
BOEKELMAN
MEMBER
The rotor has little play.
Sep 27, 2019 at 6:16 AM
CERTIFIED EXPERT
You said no spark to the plugs. That's not timing.
Sep 27, 2019 at 8:03 AM
BOEKELMAN
MEMBER
I tested the leads and they are okay.
Sep 27, 2019 at 12:28 PM
CERTIFIED EXPERT
How did you test the leads?
What was the resistance especially the coil wire?
Sep 28, 2019 at 3:35 AM
BOEKELMAN
MEMBER
It was a worn timing chain it slipped a cog. thank you for your fast replies and hints Roy.
Regards, Tony
