Hello again,
I did some research and believe you are having a problem with your G.E.M. (Generic Electrical Module). It is located under the dash on left hand side. I have attached a picture of the module (circled in red) and the connector (26 pin) that I would like you to check. I would like you to disconnect the connector and check for damaged, loose, corroded, or faulty terminals. I also have a test you can perform if you have access to a Volt Ohm Meter. Hope this helps and feel free to ask any further questions if needed. Thanks again for using 2CarPros.
Danny-
Jul 27, 2018 at 4:07 AM
