Electrical issues battery is not charging
2007 MITSUBISHI GALANT
118,513 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TED PATTI
  • 8 POSTS
My battery wont charge. I have replaced battery,alternator, and camshaft position sensor. Jump car because battery is still not charging. It intermittently charges with intermittent battery light coming on. Rpm's will shoot up to 1500 to try to charge it but wont. then if I put it in drive it shutters and wont give me power at the gas pedal but will stay running. lights and dash gauges will go on and off. I am lost at this point on what else to do. no check engine light at anytime!
Oct 20, 2016 at 6:28 PM
AL514
  • 5,465 POSTS
Can you give us the sub model please (DE, ES, SE)?
Oct 20, 2016 at 6:32 PM
TED PATTI
  • 8 POSTS
It is basic model, no DE, ES or SE that I have ever seen. It has no cruise control or anything just basic components. Sorry hope this helps.
Oct 20, 2016 at 6:35 PM
AL514
  • 5,465 POSTS
Have you had the ECM checked for codes yet? even if the light is not on.
Oct 20, 2016 at 6:49 PM
TED PATTI
  • 8 POSTS
No, I will have that checked and let you know what happens afterwards. Thanks
Oct 20, 2016 at 7:06 PM
AL514
  • 5,465 POSTS
Yes, have it checked first. it almost sounds like there may be a computer data wire that is receiving interference since you have so many lights and gauges going crazy, plus the shift in rpm's. This car does have CAN BUS data lines for communication between PCM's and the ECM.
Oct 20, 2016 at 7:29 PM
TED PATTI
  • 8 POSTS
Okay, thanks I will have it checked out today and let you know what they say. I appreciate the help.
Oct 21, 2016 at 5:33 AM
Please let us know what you find so it will help others.
Best, Ken
Oct 24, 2016 at 7:28 PM
TED PATTI
  • 8 POSTS
Hey sorry it took awhile to respond, it's my wife's car so she procrastinated on getting it to the dealership. But it's the computer not sending correct information and causing the car not to handle electrical loads. It's being reprogrammed and will be replaced if reprogramming doesn't work. Thanks for all the help!
Nov 5, 2016 at 1:34 PM
Hey Ted,
Yep that's what we thought it was too, did that fix the problem?
Nov 7, 2016 at 8:27 AM
TED PATTI
  • 8 POSTS
I'm not sure yet still waiting on dealership to do the work
Nov 7, 2016 at 10:50 AM
AL514
  • 5,465 POSTS
Make sure you get full details on what they find, you want to know exactly what was going on with the car so you don't have a repeat. If there's a electrical short somewhere that's messing with the computer, you don't want the new computer to get burned out either, a bad ground will cause all kinds of ECM problems that can be a simple fix too, so don't let them fool you into spending a ton of money.
Just lookin out for ya..
Nov 7, 2016 at 10:55 AM
TED PATTI
  • 8 POSTS
Thanks I really appreciate that and will make sure to be vigilante with them I know how dealerships can be it's all about money
Nov 9, 2016 at 9:05 PM
It's too bad our society runs on money, it should run on just helping people. That's my 2 cents :)
Nov 10, 2016 at 9:18 AM
TED PATTI
  • 8 POSTS
Unfortunately it's not, most things I can do myself or my brother in law can come over and walk me through it and it just costs parts and a pizza but this is out of our knowledge and expertise
Nov 10, 2016 at 5:26 PM
Please let us know what the dealer finds
Nov 10, 2016 at 5:46 PM
