Electrical issues
1997 NISSAN TRUCK
111,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
DENNIS M CRANE
Traveling over ten to fifteen miles on the highway the brake light and the battery light will come on at the same time appears to have a possible short because it will sputter and quit . It appears to do okay over short distances these lights may not come on and things appear to be charging I have replaced the battery and used a multi-meter to test at an idle and it appears to be at 13.8.
Feb 19, 2018 at 10:23 AM
KHLOW2008
  • 41,814 POSTS
Seems like the alternator is failing and is intermittently not charging. The brushes could be worn and is intermittently not contacting fully resulting in the non charging condition.
You need to test the charging when the light turns on.
The brake light is related to the charging warning circuit.
Feb 19, 2018 at 7:08 PM
DENNIS M CRANE
Thank you it is a good place to start. I have read on line with issues of this year from alternators to wiring harness and apparently there was a recall years ago. I have recently purchased the vehicle at a decent cost.
I appreciate your time.
Feb 20, 2018 at 8:29 PM
KHLOW2008
  • 41,814 POSTS
You are welcome. Let us know how it goes. Good luck.
Feb 22, 2018 at 6:37 AM
