Car Issue Summary (Nissan Micra Diesel 2012)
Hi, I need help diagnosing a strange electrical issue with my 2012 Nissan Micra XV Diesel.
Symptoms (only after 40+ mins of driving):
Speedometer suddenly goes crazy, then stops working
Key warning light appears on the dash
Steering becomes light like EPS is off
Car jerks while accelerating/decelerating
Car doesn’t shut off unless I hold the stop/start button for long
One time after bump-starting (without ignition ON), car didn’t start for a few mins
Airbag light is always on
Error code related to rail pressure stored
What I’ve Noticed:
Problem only happens after long drives
No parts like ECM, alternator, or battery have ever been replaced
Idle engine load is ~45%, rail pressure ~220 bar
What I’ve Done:
Checked fuses visually
Checked battery:
Engine Off-12.69v
On-14.25v
On Load like ac,radio,headlights,etc-14.05v
Any ideas on what might be causing this? Could it be ECM, IPDM, grounding issue, or something else?
Thanks in advance!
What I’ve Noticed:
What I’ve Done:
Checked battery:
Engine Off-12.69v
On-14.25v
Thanks in advance!
May 21, 2025 at 11:55 AM
