I began having startup issues a while ago. Usually, it would just take a long time to crank the starter for the engine to start. However, sometimes it wouldn't start all together. Recently, it began not starting all together more and more and it suddenly began having weird electrical issues/glitches. Such as the dashboard glitching, the gauges not reading anything, the engine shutting off if I switched on the headlights, or the power steering going out. I was able to run the codes and see that a new Crankshaft Position Sensor was needed. After replacing this part, it began starting up beautifully. However, the electrical issues keep persisting.
Any and all help/guidance would be appreciated!
Thank you very much!
Aug 7, 2023 at 1:05 PM
