Tachometer not working properly?
1996 NISSAN PATHFINDER
200,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
DV2020
So, the tachometer is going crazy. doesn't seem to affect transmission. it's just going haywire. What could be the cause?
Feb 4, 2023 at 6:01 AM
This can be caused by one of two things either the ignition system is back feeding into the tachometer circuit or the tachometer itself is going out. Can I ask if the engine is misfiring? If it has been a while, I would change out the spark plugs, cap, rotor and spark plug wires. Here is a generic guide to help walk you through the steps with instructions below for your truck.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Check out the images (below). Please let us know what you find.
Feb 4, 2023 at 12:47 PM
