As I was driving down the road my positive battery cable came loose and must have grounded multiple times as the vehicle had multiple surges in the short time, it took me to get pulled over and tighten it back up. The wipers came on and were going extremely fast enough to launch one off. The Cluster is fried well at least the gauges don't work. The warning lights come on and ESP, ABS remain on. All the lights blew the bulbs. The ABS pump motor stays on all the time and the car is in limp mode. I replaced all speed sensors. The #17 abdominal muscles fuse keeps blowing and I believe this is reason for limp mode. Going to remove the ABS module and see if it can't be fixed with a little soldering. Is that where the abs relay is? Also bought a short finder to try and locate short. All interior lights remain on even with the key out of the ignition. Already checked dimmer switch not the issue. Rear back up lights stay on as well. Any help on this would be greatly appreciated.
Feb 17, 2023 at 11:25 PM
