Electrical ignition, not starting?
1997 TOYOTA T100
264,000 MILES • 2.4L • 6 CYL • 4WD • AUTOMATIC
DANNY_KESSELS
  • 11 POSTS
The truck is in park, I insert the key and turn to 1st spot on ignition, it immediately starts to crank the engine but doesn't start, the starter motor keep turning as I move to the crank spot on ignition, turning the motor over, and it starts and I believe the starter is still turning over once it starts. I can shift the truck into neutral and everything is normal, turn ignition off, 1st spot on ignition, the starter motor is not turning. I then turn the ignition to crank mode and it turns the engine over and it starts and the starter motor stops turning. When the truck is in neutral this ignition problem doesn't exist. Operates normally. I am thinking the NSS switch might be the problem.
Feb 26, 2024 at 3:54 PM
I looked at the wiring schematic and I suspect it is one of three issues. The easiest thing to try is replacing the starter relay. It is located in the vehicle behind the left kick panel. with it with a different relay having the same part number. Next would be the neutral safety switch, but I don't think that is the case. It allows power to pass through the switch to the starter motor when it is in the correct position. It shouldn't cause what you are describing.
Now if you look at the wiring schematic below, the only time the relay should actuate to crank the engine is when the key is in the start position. At that point, you send power (from the switch) to the relay primary. In this case, I suspect something is shorting in the switch allowing power to feed in the run and start positions. We can check that by watching for power at the relay when the key is turned to the run position. However, try the relay first.
I attached the wiring schematic below so that you would have a reference. Let me know if it helps or if you have questions,
See pics below. Note: The schematic was only one page. I cut it in half to make it readable. I did overlap the two so you can follow from one to the next.
Feb 26, 2024 at 8:04 PM
DANNY_KESSELS
  • 11 POSTS
Well, the relay did not fix the problem. What's next? Again, thank you for your time. Hope to hear from you soon.
Feb 28, 2024 at 2:59 PM
Danny, I need you to remove the relay. One of the connector pins will have battery voltage at all times (white wire in pic below). The black wire should get power with the key in the start position. Check it that is the case. Also, see if the power to the black shuts off when the key is released.
See pic below.
Feb 28, 2024 at 6:45 PM
DANNY_KESSELS
  • 11 POSTS
Hi Joe, thanks again for your help. So when I measure voltage at pins 1 and 2, dvm probes on each pin, I have no voltage with ignition in the lock position I have 12 volts when ignition is in the ACC, On, and Start position. On pins 3 and 5 with dvm probes on each pin I have 12 volts at all times Lock,ACC,On, and start positions of ignition. I hope that helps. I am unable to see the color of the wires but the relay has a schematic and the back of it.
Feb 29, 2024 at 3:33 PM
Pin 1 shouldn't have power in the ACC or on position. If you have power at pin 1 with the key in ACC or run, that is going to actuate the secondary side of the relay and engage the starter.
To me, that indicates a short in the ignition switch itself. Pin 1 shouldn't have power until the switch is in the start position. It also explains the starter engaging when you turn the key to the first position. Has the starter ever engaged if the key is in the ACC position?
Let me know your thoughts.
Feb 29, 2024 at 8:28 PM
DANNY_KESSELS
  • 11 POSTS
yes, I believe it did engage in the acc position.
Mar 1, 2024 at 8:16 AM
DANNY_KESSELS
  • 11 POSTS
Should I try a new ignition?
Mar 1, 2024 at 4:49 PM
I suspect that is what will be needed. However, I attached the diagnostics for testing the switch itself. Note that pin 6 should only have continuity when the key is in the start position. If it has power in any of the other positions, replace the switch. If you find any variations to the pin connectors in pic 3, replace it.
Let me know what you find.
See pics below.
Mar 1, 2024 at 7:48 PM
DANNY_KESSELS
  • 11 POSTS
Hi Joe, I just wanted to let you know I am going to try the ignition. It won't be for a week or so, just letting you know. Thanks again.
Mar 5, 2024 at 3:23 PM
Hi Danny,
Thanks, for the update. Take your time. I'll be here. LOL
I look forward to hearing from you. If you run into any trouble, let me know.
Mar 5, 2024 at 7:39 PM
DANNY_KESSELS
  • 11 POSTS
Well, the new ignition did not fix it either.
Mar 17, 2024 at 9:50 AM
Do me a favor. At the neutral safety switch on the transmission, there will be two wires. One is black. The other wire will either be black with an orange tracer or black with a yellow tracer. Determine which you have and then check that wire for power when the key is in the start position.
If there is power, with the vehicle in park, check the black wire out for power with the key in the start position.
Let me know what you find. We are going to walk through this one section at a time. LOL
joe
Mar 17, 2024 at 7:55 PM
