I had driven the jeep about fifteen minutes and shut it off for about an hour. When I tried to start it, the dash lights did the self test and radio came on as usual, the starter started to engage, and then everything went out. I have headlights, dome lights, and horn, but nothing happens at all when I turn the ignition. I have changed the ignition switch, and the ignition switch actuator. I have checked and I have power coming to the ignition switch, but still nothing happens at all when I turn the key over. All of the fuses in the PDC under the hood are good, and all have 12.5 volts going to them. I have taken the starter off and had it tested, it is fine, and I have changed the starter relay in the PDC. I am normally really good with typical starting issues, but this one has me stumped. I am thinking a bad ground, but I have checked continuity between the engine block, body, and frame and they all seem good. Help me! LOL
Jun 11, 2017 at 2:36 PM
