The Manifold Absolute Pressure (MAP) sensor is mounted to the front of the intake manifold air plenum box. It's approx behind the alternator. To remove it, simply turn it counterclockwise a 1/4 turn. When you reinstall it, make sure the o-ring is in good condition and sealing.
Here are the directions. The attached pics correlate with the directions.
2007 Dodge or Ram Truck RAM 1500 Truck 2WD V8-5.7L VIN 2
5.7L V-8
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Manifold Pressure/Vacuum Sensor Service and Repair Removal and Replacement Sensor-MAP Removal 5.7L V-8
5.7L V-8
5.7L V-8
pic 1
pic 2
1. Disconnect electrical connector at sensor by sliding release lock out. Press down on lock tab for removal.
2. Rotate sensor (3) 1/4 turn counterclockwise for removal.
3. Check condition of sensor O-ring.
Installation is the reverse of removal.
___________________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 27, 2021 at 9:14 PM
