No crank and transmission gear selector flashing?
2001 CADILLAC ELDORADO
60,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RAY KANIA
No crank, ground issue gear selector flashing.
Aug 1, 2021 at 1:07 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds that you might have a fault code stored in the transmission system due to the gear selector light flashing on the dash. It could also be the neutral safety switch on the transmission. The best thing for you to do is have a CAN scan- Controller Area Network performed to determine what fault codes are stored in your vehicle's computer. Here is a tutorial showing what is involved with a CAN scan:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Once you have this performed get back to us with any code numbers and we can then properly diagnose the issue your vehicle is having. Let us know. Hope this helps and thanks for using 2CarPros.
Aug 1, 2021 at 2:56 AM
