Electrical, erratic idle
1992 HONDA PRELUDE
220,000 MILES • 2.3L • MANUAL
ZEDRIK ARCILLA
  • 5 POSTS
Hi, good day. I just wanted to ask some few question. Firstly I got this car as a payment from a friend. It happened the third day I had it. It is an Si. I was test driving it to see if it still good.. it runs smooth for the day but the next day, I was gonna use it for work suddenly it wouldn't start up as in no electric current even on the dash so I changed the battery but still was not doing anything so I left it for the day. the next day it started right up. What could be wrong?
Next thing happen was I tried to start it again but it sound like a flickering relay but I figured that the sound was coming from the viper alarm. Should I have the alarm replaced or removed?
When I drove it the first time, I noticed that when I am on a full stop, my RPM goes up and down. I replaced the IACV already but still doing it. Help
And lastly. I took it to a smog place and it didn't pass because the guy told me that my RPM on 15 and 25 mph is about 10 points higher than it should be.
Mar 19, 2019 at 6:07 AM
JOETECHPRO
  • 705 POSTS
Hey ZEDRIK ARCILLA,
For the erratic idle please follow the guide below and check for vacuum leaks:
Also the video below shows the process:
https://www.youtube.com/watch?v=xN5pcM-5bso
Let me know if you find anything or have any questions regarding the process.
Please be careful when spraying carburetor cleaner around the engine bay, it is flammable so keep it away from the exhaust and have a fire extinguisher to hand.
Removing the aftermarket alarm would rule out this causing the issue, if it is intermittent it could be hard to pinpoint the cause.
Regards, Joe
Mar 19, 2019 at 12:08 PM
ZEDRIK ARCILLA
  • 5 POSTS
I will do that and let you know. Thanks
Mar 20, 2019 at 7:50 AM
JOETECHPRO
  • 705 POSTS
Hey ZEDRIK ARCILLA,
Perfect, please do let us know how you get on or have any questions regarding the test.
Regards, Joe
Mar 20, 2019 at 2:48 PM
ZEDRIK ARCILLA
  • 5 POSTS
So, after work this what happened when I try to run the car it wont start. I heard one click while trying to start the car like a shorted sound but I checked everything even the fuse. There was no blown fuse or anything. So I tried to jump start it and tried to start it while the booster cable is plugged. lights worked before I start the car. But when I start it everything shuts off. So what could it be?
Mar 20, 2019 at 7:48 PM
ZEDRIK ARCILLA
  • 5 POSTS
I remember earlier while checking for leaks, I replaced a hose somewhere on the top left side of the engine bay and I unplugged a sensor to get to the hose. then when I replaced the hose I forgot to plug in the sensor then I started the car. Then everything went off.
Mar 20, 2019 at 8:15 PM
JOETECHPRO
  • 705 POSTS
Hey ZEDRIK ARCILLA,
With your starting issue it sounds like you have a bad starter or or bad connections to the starter.
Please read through the guide below on how to check this.
https://www.2carpros.com/articles/starter-not-working-repair
Any questions let us know.
Regards, Joe
Mar 21, 2019 at 8:40 AM
ZEDRIK ARCILLA
  • 5 POSTS
One last thing, All the past issues are done except it will not start anymore unless I jump start it. I bought a new battery but still wont turn.
Mar 25, 2019 at 7:01 PM
JOETECHPRO
  • 705 POSTS
Hey ZEDRIK ARCILLA,
Are the battery terminals clean and tight?
Please read through the guide below.
Let me know if that makes any change.
Are you connecting the jumper cables directly to the battery terminals?
Regards, Joe
Mar 26, 2019 at 8:18 AM
