No crank, no,fuel, no fire, no check engine light
2007 NISSAN FRONTIER
198,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
SHANE RICHISON
No alarm (security light) and no start! after vehicle lights were left on and discharged the battery , tried to jump start , and replaced the battery with new one! one of the codes my modis scanner shows is code 1610 NATS malfunction! I have individually tested each relay and fuse. replaced the only two of each i found to be bad , and checked all fusible links, and even done a wiggle test on major connectors . if i use a jog switch on the starter solenoid , the engine will crank , but still has no fuel , no fire or injector signal.
Jul 11, 2019 at 7:50 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like you could have a problem with Crankcase Position Sensor (CKP). Here is a link for you to go to:
Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 12, 2019 at 3:18 PM
