that's very strange i have no cranking problems.
so Roy let me give you a little back round that started this problem.
i was preforming a repair on my fuel injector, i disconnected the neg battery terminal when i was doing the repair. made sure it wasn't touching anything aka the frame or body. pulled it all apart intake manifold, injectors properly disconnected all harnesses. put it all back together when i was putting it together i noticed the neg battery terminal was all corroded. so i cut the wires and installed clamp style terminals. started the truck up my repair looked good. I noticed my radio wasn't going on so i checked the ground cable. the battery terminals i bought were bad. so i ordered a better set on online with ring terminals. trucks ground wire fixed. all good. started driving the truck and noticed my right blinder went out than came back on for a couple of hours. than went back out. so that's when i checked all the fuses and found no power to these fuses.
Mar 13, 2019 at 4:25 PM
