Electrical issues after installing new radio
2000 GMC SIERRA
127,000 MILES • 6.5L • TURBO • AUTOMATIC
RANDYE2018
Installed new radio truck ran and was fun shut it off and now it will not start. just clicks there is no power. Lights go on, dash lights up, everything else runs but it will not start. Batteries are good started fuses everything is great but the truck will not start since the new radio was installed other than the night it was put in has not worked since then and I did have it running after my radio was installed. This started twenty four hours after the radio was installed help me what could it be.
Feb 14, 2018 at 11:27 AM
CARADIODOC
  • 34,306 POSTS
Everything you described sounds like the battery is drained. Charge it at a slow rate for an hour, then try to start the engine. If the battery runs down overnight again, the radio is connected improperly. If the radio does not turn off when the ignition switch is off, the radio's power wire is connected to the wrong place.
Feb 14, 2018 at 2:50 PM
