Bought the car cheap cheap.
cabin wiring harness was cut down the middle by the SRS unit.
rewired it back together and now the check engine light on and codes PO118
ECT sensor 1 circuit high input
PO122
TP sensor (A) voltage low
PO135
HO2S (SI) heater failure
P0141
HO2S S2 heater circuit malfunction
P1660
Attached line signal failure.
Ignore the o2 sensor as exhaust was cut at the manifold.
Aftermarket radio has power but no sound and fuses are fine have not installed the dashboard side of the center console.
when I use the window switches the idle fluctuates.
PO122
PO135
P0141
P1660
Jan 2, 2021 at 12:21 AM
