Odd Electrical Problem
2007 MAZDA 6
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANIANNE
I was pulling out of a parking spot and when I put my car in reverse it jerked and I lost power to all the gauges. Then the windows lost power. The car goes in reverse and it moves forward sluggish but it starts just fine. What could it be?
Jul 11, 2016 at 12:13 PM
HMAC300
  • 48,601 POSTS
see if there are any codes auto parts does it for free but you may have damaged a transmission seal or clutch plate however. if you can check trans fluid a lot of the newer cars you can't however.
Jul 11, 2016 at 1:30 PM
DANIANNE
The tranny works it just got sluggish after I lost power to the panel and the gauges
Jul 11, 2016 at 2:20 PM
KHLOW2008
  • 41,814 POSTS
A power supply source is being interrupted. It could be a bad connection somewhere and you need to have it checked by an auto electrician. If you are a DIY person, look under the hood for loose wire harnesses flying around.
Jul 15, 2016 at 8:01 AM
