There are 4 fuses that run the system that need to be checked first. here is a guide to help test the fuses and the fuse locations well with the turn signal wiring diagrams so you can see how the system works and which fuses to check:
If the fuses are good chances are the smart junction box (BCM) will need to be replaced which I have included instructions for as well. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Sep 27, 2019 at 5:45 PM
