Okay. Can you get a picture of the speed sensor that you replaced in the transmission? I just want to verify this was the output sensor.
Also, if this is ok then the likely cause of this is the cluster itself. This cluster has a logic circuit board that takes the speed sensor input and displays the speed and odometer. So, if this is getting a speed signal then the cluster is the likely issue.
Apr 13, 2022 at 6:27 PM
