Which fuse is it that you removed? I'm looking at the wiring schematic and it shows power from the body control module for the light. I assume the rear is not doing this. So, that tells me there is a short to power between the BCM and bulb.
I attached the entire wiring schematic below for the exterior lighting circuits. I highlighted the wiring involved specific to the front/left signal/parking light.
Here is what I want you to do. To determine if there if the short is at or before the BCM, I need you to disconnect the BCM. Only do this after disconnecting the battery. Once the battery is disconnected, disconnect the BCM and then reconnect the battery.
With the BCM disconnected, does the light remain on?
Let me know what you find. Also, if the light is off with the BCM disconnected, inspect the connector at pin 4 (supply voltage). Disconnect the battery, reconnect the BCM, and then reconnect the battery. Once it's back together, check for constant power at pin 4. IF there is, disconnect the signal switch to see if power stops and let me know the results.
By doing this, I am hoping to minimize the number of areas that can be causing the issue.
See pics below. Note: The original schematic was 3 pages long. I had to cut each pin in half to make it readable for you. I did overlap them so you can follow from one to the next.
Jan 31, 2022 at 7:37 PM
