my temperature gauge seems to have stopped working?
2009 PONTIAC TORRENT
139,350 MILES • 3.4L • V6 • 4WD • AUTOMATIC
RONALD PATRICK RIVINIUS
  • 8 POSTS
Now, today, my temperature gauge seems to have stopped working (just sits at low and doesn’t move) and both radiator fans stay running all the time while vehicle is running. Display instrument information panel shows engine hot a/c off and service tire monitor system, check engine light is on and (blinking) yellow exclamation point is on.
Heat works and vehicle doesn’t seem to be overheating really, even though the above is occurring.
Feb 25, 2025 at 2:06 PM
Because you have a check engine light on I would run the codes to confirm the engine coolant sensor is out of range. Here is a guide to help you run the codes and the sensor locations as well.
Feb 27, 2025 at 11:19 AM
