When you say a chime noise, can you get a recording of this so that we can better understand?
However, I suspect this is either a relay issue or an electrical short.
Also, we need to check and make sure the battery is not damaged. It needs a load check shown in this guide:
Next thing is we need to remove the fuses when this is happening to find out what circuit the issue is on. I would start with the fuses shown in this diagram below.
Let me know if you have questions on this and what you find and we can go from there. Thanks
Apr 12, 2021 at 4:47 PM
