When driving the door locks unlock and lock
2006 CHEVROLET IMPALA
150,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
AH8007
  • 68 POSTS
When I am driving my sedan door locks unlock and lock. Car seems to be going in and out of park to on my instrument cluster while driving.
What do you think can cause this?
I attached a video below
Apr 25, 2020 at 7:52 AM
I watched the video and noted that the shift indicator would briefly jump to P when the locks were actuated. When you shift the car out of Park the doors automatically lock. There is a sensor in your shifter assembly which detects when the shifter has moved from park and then this locks your doors. On the other hand, the automatic door locks are controlled by the body control module which could be failing as well.
There is a door lock relay, but it is part of a printed circuit board and not replaceable.
Before we jump the gun and start checking or replacing everything, lets start by checking for a weak ground. If you look at the pic I attached, it shows where the ground for the circuit is located. Check that first.
Let me know what you find.
Apr 25, 2020 at 8:41 PM
AH8007
  • 68 POSTS
Which one is A pillar?
Apr 26, 2020 at 5:45 PM
I attached a pic below to help. The arrow I added points to the front of the vehicle.
Let me know if this helps.
Apr 26, 2020 at 8:12 PM
AH8007
  • 68 POSTS
Ground came back good.
Apr 27, 2020 at 4:06 AM
Then we need to have the computer scanned to see if there are diagnostic trouble codes that could relate to the transmission range sensor, shifter assembly, lock relay, or an issue with the body control module.
I realize not everyone has a scanner but often times a parts store will do it free of charge. Have that done and let me know if any codes are present.
Apr 27, 2020 at 8:06 PM
AH8007
  • 68 POSTS
After scanning there are no codes stored on the vehicle.
Apr 27, 2020 at 10:16 PM
I have to be honest. I spoke with another tech and we both feel it is related to the body control module (BCM). He is recommending a specific type of scan which check the can buss system. Watch this video:
https://www.youtube.com/watch?v=u-4syLc-ifQ&feature=youtu.be
Apr 28, 2020 at 7:53 PM
AH8007
  • 68 POSTS
I replaced the shift assembly and it's still doing the same thing. I have a donor car that does not do this. So the parts are going to be free.
Apr 30, 2020 at 11:46 AM
Can you check the body control in both vehicle and see if they have the same part number?
I attached a pic of location. The only concern is reprogramming. This will need done if replaced.
Apr 30, 2020 at 9:11 PM
AH8007
  • 68 POSTS
The BCM didn't fix it.
May 7, 2020 at 4:48 PM
AH8007
  • 68 POSTS
It seems to do it when I hit bumps in the road.
May 7, 2020 at 4:49 PM
It sounds like a simple connection issue, but where is it located. I looked through to identify different things, and I really feel you need to have it scanned with a can scanner. It will identify where the fault lies.
May 7, 2020 at 9:21 PM
Yes, it sounds like a ground issue. Can you start the car without driving it and move wiring harnesses around? PCM and BCM to see if you can get it to act up?
May 8, 2020 at 12:10 PM
AH8007
  • 68 POSTS
No it does not do it when I shake the harness. Only seems to do it when the car is at operating temperature and when hitting bumps. Lights in the car also seem to flicker when it does it too.
May 14, 2020 at 5:19 AM
I am wondering if the alternator is throwing AC voltage. we can be sure by following this guide:
May 14, 2020 at 12:26 PM
AH8007
  • 68 POSTS
Turned out to be the red positive battery wire was grounding out on the pulley on the car.
May 20, 2020 at 4:14 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
May 20, 2020 at 10:47 AM
