electrical
1990 FORD F-250
400,000 MILES • 3.2L • V8 • 2WD • MANUAL
DONNY CLOSS
i have an electrical issue that i cant figure out i have changed the coil, spark plugs, distributor cap and rotor, checked all the wires in the engine bay for broken grounds and corrosion found nothing but still not getting spark to the plugs.
Mar 29, 2017 at 7:41 AM
CARADIODOC
  • 34,306 POSTS
There was no 3.2L engine for that truck. Also, you know all of the spark plugs didn't fail at the same time, and those won't cause loss of spark. You overlooked the two most common causes of no spark. Those are the TFI module on the side of the distributor, and the pick-up assembly in the distributor.
Mar 29, 2017 at 1:12 PM
