Shut off while driving and will not start?
2001 MAZDA MPV
160,000 MILES • 2.6L • 6 CYL • 4WD • AUTOMATIC
JGROVER33825
Instrument panel went out and then it shut off while driving a few days later now it won't start.
Sep 22, 2024 at 12:56 PM
When you try starting it, does anything happen? For example, do you hear a click from the starter or a relay?
Have you had the battery tested to confirm it hasn't failed or is weak? Take a look through this link and let me know if it helps:
Also, let me know if the battery has been tested and exactly what happens when you try starting it.
Sep 22, 2024 at 9:16 PM
