ELECTRIC WINDOWS NOT WORKING
2006 MAZDA 3
210,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
EDDY JANUARY
Windows stopped working, no power at main switch and individual switches. I checked on the fuse box cover but could not find the fuse for the windows.
Jul 20, 2016 at 4:16 AM
WRENCHTECH
  • 20,761 POSTS
There are two 30 amp fuses that power the ignition switch which in turn powers the window switch. After the ignition switch, there are individual fuses (F77 and F78) for the left and right switches so you have to see what actually still works. If all the fuses are still good, then you have to start looking at the wiring going into the door for breaks. The feed wire is green with blue. The main ground wire is black and that is very important also.
Jul 20, 2016 at 4:32 AM
