Electric sunroof fault on focus cc3
2008 FORD FOCUS
26,500 MILES • 2.0L • 4 CYL • TURBO • FWD • MANUAL
MAHOGANYBOB
After 3 month layup - outside of garage with tricle charge battery charger attached - on start up 'roof malfunction service required ' warning came on.boot difficult to close and heated rear window not working.
Took to ford main garage Lincoln and again to Ford Tatterhall Lincs - neither garage could find or cure the electrical fault - after about 4 hours look. Suggested that next step was to change the roof control module -Cost £775 plus labour charge. Even then could not guarantee to cure the fault.
Any thoughts or suggestions welcome please - is this a known fault.
Thanks
Bob Manser
May 2, 2015 at 7:42 AM
HMAC300
  • 48,601 POSTS
there are no tsb's on this but have them do a pinpoint test A and also check adjustments......I think they are just trying to replace it in hopes of fixing it.
May 3, 2015 at 4:32 PM
