How to pump out old gas from the tank using the electric fuel pump?
2012 HYUNDAI VELOSTER
135,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
VELMAN12
  • 4 POSTS
I have a keyless push-button remote start configuration and would like to pump out old gas from the tank using the electric fuel pump. How do I electrically do this? Thanks much in advance!
May 5, 2023 at 3:48 PM
STEVE W.
  • 15,113 POSTS
The easy way would be to pull the fuel pump relay out of the engine room relay box and jumper power from terminal 1 to 2, that will power the pump in the way you want. The attached should get you to them.
May 5, 2023 at 4:45 PM
VELMAN12
  • 4 POSTS
Thank you for your prompt and very informative reply, Steve! I will try this method and advise you once I have completed it. Best regards, Reg
May 5, 2023 at 6:49 PM
VELMAN12
  • 4 POSTS
Hi Steve! Your procedure worked to the letter! I was able to drain my gas tank in a short period of time with the electric fuel pump. Thank you!
May 6, 2023 at 4:53 PM
STEVE W.
  • 15,113 POSTS
You are welcome. It's a process that gets used a lot, much easier to drop an empty tank over one with 100 pounds of flammable liquid in it.
May 6, 2023 at 6:00 PM
VELMAN12
  • 4 POSTS
Couldn't agree more, Steve! Have a great day! Best regards, Reg
May 7, 2023 at 3:28 AM
