Electric doors wont unlock from inside or outside
1996 TOYOTA TACOMA
2,000,000 MILES • 6 CYL • 4WD • MANUAL
LILBLONDNIKKI
Both the doors wont unlock from inside or outside. The door handle is broken on the inside of the driver door, but the passenger wont open or unlock either.
Sep 28, 2016 at 8:20 PM
HMAC300
  • 48,601 POSTS
it may have a broken clip that is on a rod if you can hear actuator working. if not working then check fuses, first under hood. your key lock should still work though. if your key fob wont let it work take to an auto parts and have them the check battery and see if key fob works.
Sep 29, 2016 at 6:13 AM
