traction control light and tire pressure lights turned on?
2014 MAZDA CX-5
101,000 MILES • 2.2L • 2WD • MANUAL
IWILLBEFOREVERYOUNG
The traction control light has come on and the tire pressure light. Had it on a diagnostic machine and it won't clear either of them off. It has had a new tire and alloy on (well new to me) got it from a scrap yard and put it on myself. Don't know whether that could be the issue or what. I have just bought a new speed sensor that I will Fitbit first any ideas. thanks
May 3, 2023 at 4:31 AM
What are the codes that are present? Also, is the wheel you used the same size as well as the tire? As far as the sensor, if you used the one that was in the used wheel, it won't work unless it is programmed to the vehicle. Also, new sensors also need to be programmed in many cases.
Let me know as much as you can as far as the issue. Also, let me know if the lights came on at the same time.
May 3, 2023 at 6:34 PM
