make sure switch on headlamp is off and not leaving it on. then have it scanned for codes as it may be a body module problem. a mechanic will have to do that.
Aug 5, 2016 at 12:09 PM
DEXTER YOUNG
MEMBER
If I Move the key around the lights go off then radio comes on.
Aug 5, 2016 at 12:17 PM
HMAC300
CERTIFIED EXPERT
well it may be a bad ignition switch as well back feeding the body module causing these problems it needs to be physically checked out.
