If nothing is working, I need you to locate the fuse/fusible link box under the hood. See pic 1 below for the location.
Next, in pic 2, I highlighted a fusible link that I need to be checked. A fusible link is basically a fuse but is designed differently to do the same thing. Confirm it is good. Also, confirm there is power to and from it.
Also in pic 2, I highlighted and circled the power supply wire to the box. Simply confirm there is 12v present on that wire/bolt. You can use a test light, multimeter, or voltmeter.
Here is a link that shows how to use a test light:
Let me know what you find.
See pics below.
Jun 29, 2021 at 9:49 PM
