B1493 - Occupant Classification System Communication Error
B2500 - Airbag Warning General Failure
B2502 - Airbag Telltale Lamp Failure
These codes are telling you that you have a wiring issue or module issue in the communication harness for the airbag system. This is a very sensitive system and I would highly recommend taking this to a dealership if you are not comfortable diagnosing wiring and airbag systems. The reason I say that is trying to diagnose and airbag issue you could inadvertently cause the airbags to deploy.
If you are comfortable then I attached the testing that we need to do. We need to focus on the B1493 code as they other 2 are only informational.
However, once we get past the initial inspection of the wiring we get into needing CAN communication tools to monitor and inspect the wiring properly. Then we need a scan tool shown in the testing. Unfortunately to properly diagnose this we need those tools because they don't give a way to test the airbags with meters or more common electrical tools. They did this so that it is hard for non dealers/shops to work on this system.
Run through this and let me know what questions you have.
Jul 10, 2020 at 5:12 PM
