Okay, I attached a flow chart for checks needed for this code. The most common reason for this code is low fuel pressure from a bad fuel pump, but it needs to be confirmed with a fuel pressure test. if you do not have a tester, you can rent one at a parts store.
Mar 5, 2018 at 6:41 AM
