I have a 93 Camry 2.2L and I want to troubleshoot the EGR valve system. I know there a re a few compoents. I believe that the EGR is intemittently opening at idle and while on highway. I get bucking and chugging on th ehighway and bad idle and sometimes stall out at idle. No check engine lights. I want to trouble shoot the EGR valve , modulator, ported vacuum valve and I think there is a solenoid in the system in back under the intake. I want to trouble shoot before I take EGR off to clean. Basically I am trying to rule out my EGR system as I did an inspection of the ignition system and checked for major vacuum leaks by spraying carb cleaner on areas.
Feb 1, 2021 at 11:12 PM
