Good morning,
If you have an issue with this valve, you need to replace it. The valve cannot be cleaned due to the area that has the soot build up is not accessible for any service.
I attached the procedure below with a picture for you.
1. Remove the EGR valve.
1. Disconnect the vacuum line.
2. Disconnect the EGR tube.
3. Remove the EGR valve and discard the gasket.
NOTE: The EGR valve sealing surfaces are soft metals.
2. To install, reverse the removal procedure.
1. Carefully clean all sealing surfaces and install a new EGR valve gasket.
Oct 15, 2020 at 4:57 AM
