The multi air engine does not have an EGR valve as it uses variable valve timing and some other strategy to eliminate the need for it.
Here are a couple guides that will help with those that need to test their EGR and then a guide on VVT technology:
https://youtu.be/DqUCbbKdWf4
https://www.2carpros.com/articles/how-camshaft-variable-valve-timing-works
Also, see below where the manual says that the EGR may not be equipped.
Please let us know if you have other questions.
Thanks
Jan 12, 2022 at 4:39 PM
